Ana içeriğe geç
Bicycle Handlebar Tape Replacement
Neye ihtiyacın var
  1. Bicycle Handlebar Tape Replacement, Handlebar Tape: adım 1, 3 resimden 1. Bicycle Handlebar Tape Replacement, Handlebar Tape: adım 1, 3 resimden 2. Bicycle Handlebar Tape Replacement, Handlebar Tape: adım 1, 3 resimden 3.
    • Undo the brake cables holding the brake calipers under tension.
    • Depress the brake/shift levers (brifters) and insert a 5mm Allen key into the internal bolt. This bolt secures the brifters to the handlebar.
    • With the 5mm Allen key, loosen and temporarily remove brifters.
  2. Bicycle Handlebar Tape Replacement: adım 2, 3 resimden 1. Bicycle Handlebar Tape Replacement: adım 2, 3 resimden 2. Bicycle Handlebar Tape Replacement: adım 2, 3 resimden 3.
    • Remove the old tape and discard.
    • Pour some rubbing alcohol on the rag and clean any old adhesive residue off the handlebar.
  3. Bicycle Handlebar Tape Replacement: adım 3, 3 resimden 1. Bicycle Handlebar Tape Replacement: adım 3, 3 resimden 2. Bicycle Handlebar Tape Replacement: adım 3, 3 resimden 3.
    • Starting on the right side of the handlebar, wrap the new tape around the end in a clockwise direction moving inward.
    • Be sure to wrap the tape tight, but don't pull so hard that it rips!
    • Using the scissors, cut the tape at an angle towards the outside of the bar.
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured here)
  4. Bicycle Handlebar Tape Replacement: adım 4, 3 resimden 1. Bicycle Handlebar Tape Replacement: adım 4, 3 resimden 2. Bicycle Handlebar Tape Replacement: adım 4, 3 resimden 3.
    • On the left side of the handlebar, wrap the tape around the end in a counter-clockwise direction moving inward.
    • Wrap tight, but don't rip!
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured).
  5. Bicycle Handlebar Tape Replacement: adım 5, 2 resimden 1. Bicycle Handlebar Tape Replacement: adım 5, 2 resimden 2.
    • Using the 5mm Allen key, reattach and tighten the brifter levers onto the handlebar.
  6. Bicycle Handlebar Tape Replacement: adım 6, 2 resimden 1. Bicycle Handlebar Tape Replacement: adım 6, 2 resimden 2.
    • Reattach the brake cables to the brifters and brake calipers
    • Depress the brake levers a couple of times to test and confirm that the cables were reinstalled properly before riding.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Jordan Byrnes
132 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S1-G70, Coad Spring 2017 UC Davis, Team S1-G70, Coad Spring 2017 üyesi
UCD-COAD-S17S1G70
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 835
