Ana içeriğe geç
Bike Chain Installation
Neye ihtiyacın var
  1. Bike Chain Installation, Bike Chain Installation: adım 1, 2 resimden 1. Bike Chain Installation, Bike Chain Installation: adım 1, 2 resimden 2.
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
  2. Bike Chain Installation: adım 2, 2 resimden 1. Bike Chain Installation: adım 2, 2 resimden 2.
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
aaron thielk
1.903 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G13
4 Üyeler
17 adet Kılavuz yazıldı
2Kılavuz Yorumları
what do you do if the Chain keeps Falling off when your Riding the Bike an the Chain still rubs against the tire .
Anthony - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 26
Son 30 gün: 68
Her zaman: 16,488
