Ana içeriğe geç
Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement
Neye ihtiyacın var
  1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: adım 1, 3 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: adım 1, 3 resimden 2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: adım 1, 3 resimden 3.
    • Cut and remove any zip ties securing the throttle cable.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 2, 2 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 driver to remove the screw securing the lower end of the throttle cable.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 3, 2 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 3, 2 resimden 2.
    • Remove the bracket securing the lower end of the throttle cable.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 4, 3 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 4, 3 resimden 2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 4, 3 resimden 3.
    • Rotate the lower end of the throttle cable to detach it from the throttle.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 5, 3 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 5, 3 resimden 2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 5, 3 resimden 3.
    • When reinstalling the throttle control cable, check to make sure that the throttle control moves the throttle through its full range of motion.
    • If necessary, loosen the screw securing the lower end of the throttle cable and adjust the position of the cable. Re-tighten the screw and check to make sure that the throttle moves through its full range of motion.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 6, 2 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 6, 2 resimden 2.
    • Use a 7/16" wrench or deep socket to remove the cap from the throttle control.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 7, 2 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 7, 2 resimden 2.
    • Advance the throttle control to expose the gear rack containing the upper end of the throttle cable.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 8, 3 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 8, 3 resimden 2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 8, 3 resimden 3.
    • Separate the gear rack from the upper end of the throttle cable.
    • Lift and remove the gear rack from the throttle control.
    • If the gear rack doesn't fully detach, advance the throttle control lever a little farther.
    • Lubricate the gear rack with a bit of lithium grease during reassembly.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 9, 3 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 9, 3 resimden 2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 9, 3 resimden 3.
    • Use a 1/2" wrench to unscrew the upper end of the throttle cable from the throttle control.
    • Slide the throttle cable down out of the bottom of the throttle control, and remove the cable.
  10. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: adım 10, 2 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: adım 10, 2 resimden 2.
    • Use a Phillips #2 driver to remove the two screws securing the throttle control.
    • While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
  11. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 11, 2 resimden 1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: adım 11, 2 resimden 2.
    • Remove the throttle control.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jeff Suovanen
431.464 İtibar
259 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
Bir Yorum
the part # is incorrect, it appears that it is 440014 not 440013
JACOB - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,029
