Ana içeriğe geç
Bionaire BAP 600 Transformer Replacement
Neye ihtiyacın var
  1. Bionaire BAP 600 Transformer Replacement, Control Board: adım 1, 1 resimden 1.
    • Unplug 7 pin connector
  2. Bionaire BAP 600 Transformer Replacement: adım 2, 1 resimden 1.
    • Unplug 2 pin wires which connects the front LED's.
  3. Bionaire BAP 600 Transformer Replacement: adım 3, 2 resimden 1. Bionaire BAP 600 Transformer Replacement: adım 3, 2 resimden 2.
    • Remove two screws
  4. Bionaire BAP 600 Transformer Replacement: adım 4, 1 resimden 1.
    • Unplug pins
    • Use scissors to cut zip ties
  5. Bionaire BAP 600 Transformer Replacement: adım 5, 3 resimden 1. Bionaire BAP 600 Transformer Replacement: adım 5, 3 resimden 2. Bionaire BAP 600 Transformer Replacement: adım 5, 3 resimden 3.
    • Unplug rest of pin connections
    • Remove Neutral and Hot wires
    • They are the two black wires
    • Pull them out
  6. Bionaire BAP 600 Transformer Replacement: adım 6, 3 resimden 1. Bionaire BAP 600 Transformer Replacement: adım 6, 3 resimden 2. Bionaire BAP 600 Transformer Replacement: adım 6, 3 resimden 3.
    • Unscrew two screws
    • Inspect capacitor for any bulges ( if it has a bulge , it means it is need to be replaced)
    • Check for burnt solder in the back of circuit board
  7. Bionaire BAP 600 Transformer Replacement, Transformer: adım 7, 2 resimden 1. Bionaire BAP 600 Transformer Replacement, Transformer: adım 7, 2 resimden 2.
    • Use screwdriver to remove screws
Sonuç
Alexander Tarancon
49 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 4-4, Baechle Fall 2016 IUPUI, Team 4-4, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S4G4
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 194
