Ana içeriğe geç
Bissell Pet Hair Eraser Motherboard Replacement
Neye ihtiyacın var
  1. Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: adım 1, 2 resimden 1. Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: adım 1, 2 resimden 2.
    • Firmly grasp the handle and press the release button.
    • Gently pull the dirt cup down and away from the vacuum body.
  2. Bissell Pet Hair Eraser Motherboard Replacement, Power Button: adım 2, 2 resimden 1. Bissell Pet Hair Eraser Motherboard Replacement, Power Button: adım 2, 2 resimden 2.
    • Remove the six 1.2 mm Philips #2 screws from the handle and base.
  3. Bissell Pet Hair Eraser Motherboard Replacement: adım 3, 2 resimden 1. Bissell Pet Hair Eraser Motherboard Replacement: adım 3, 2 resimden 2.
    • Grasp each half of the body and gently pull apart.
    • The green handle, power button, charge light lens, and dirt cup release are not fastened in place.
    • Once the case is split apart these items may come dislodged.
  4. Bissell Pet Hair Eraser Motherboard Replacement: adım 4, 3 resimden 1. Bissell Pet Hair Eraser Motherboard Replacement: adım 4, 3 resimden 2. Bissell Pet Hair Eraser Motherboard Replacement: adım 4, 3 resimden 3.
    • The power button can be removed by gently lifting it off the circuitry.
  5. Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Remove the battery plastic hold down by lifting it off the tabs.
    • Remove the battery by lifting straight up.
    • Position the battery aside.
  6. Bissell Pet Hair Eraser Motherboard Replacement: adım 6, 3 resimden 1. Bissell Pet Hair Eraser Motherboard Replacement: adım 6, 3 resimden 2. Bissell Pet Hair Eraser Motherboard Replacement: adım 6, 3 resimden 3.
    • Grasp the charger port and remove it by lifting it straight out of the case.
    • Set the charger port next to the battery.
  7. Bissell Pet Hair Eraser Motherboard Replacement: adım 7, 2 resimden 1. Bissell Pet Hair Eraser Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the power button and charge LED light by gently pulling straight out of the case.
    • The vacuum motor can be removed by pulling straight out of the case.
    • All internals are now removed.
    • Set the case halves aside.
  8. Bissell Pet Hair Eraser Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the two 1 mm Phillips #2 screws in the shown locations.
  9. Bissell Pet Hair Eraser Motherboard Replacement: adım 9, 2 resimden 1. Bissell Pet Hair Eraser Motherboard Replacement: adım 9, 2 resimden 2.
    • Disconnect the power leads from the vacuum motor.
    • The red power lead goes on the terminal with the visible red dot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 352
