Ana içeriğe geç
Bissell Pet Hair Eraser Motorized Brush Belt Replacement
Neye ihtiyacın var
  1. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: adım 1, 2 resimden 1. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: adım 1, 2 resimden 2.
    • Turn power OFF.
    • Detach motorized brush from the vacuum.
  2. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 2, 2 resimden 1. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 2, 2 resimden 2.
    • Use a spudger or a coin to turn the circular lock clockwise to unlock the brush roll.
    • Remove the lock cover.
  3. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 3, 1 resimden 1.
    • Lift brush out of the enclosure.
  4. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 4, 3 resimden 1. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 4, 3 resimden 2. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 4, 3 resimden 3.
    • Remove the four 13.0 mm Phillips #0 screws and remove the green cover.
  5. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 5, 1 resimden 1.
    • Take out the motor assembly.
  6. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush Belt: adım 6, 1 resimden 1.
    • Take the belt off the gear by using a spudger.
  7. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 7, 3 resimden 1. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 7, 3 resimden 2. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: adım 7, 3 resimden 3.
    • Grab the new belt and slide it on to the two gears.
    • Place the motor assembly back into the motorized brush enclosure.
Sonuç
To reassemble your device, follow the motorized brush disassembly instructions in reverse order.
Roman Dyagilev
217 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Wilson Fall 2017 IUPUI, Team S4-G4, Wilson Fall 2017 üyesi
IUPUI-WILSON-F17S4G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 411
