Ana içeriğe geç
Bissell PowerForce Compact Belt Replacement
Neye ihtiyacın var
  1. Bissell PowerForce Compact Belt Replacement, Belt: adım 1, 3 resimden 1. Bissell PowerForce Compact Belt Replacement, Belt: adım 1, 3 resimden 2. Bissell PowerForce Compact Belt Replacement, Belt: adım 1, 3 resimden 3.
    • Remove the 5 screws from the brush plate with the phillips screwdriver.
  2. Bissell PowerForce Compact Belt Replacement: adım 2, 2 resimden 1. Bissell PowerForce Compact Belt Replacement: adım 2, 2 resimden 2.
    • Lift off the brush plate by grabbing both ends of the plate and lifting the plate up.
  3. Bissell PowerForce Compact Belt Replacement: adım 3, 3 resimden 1. Bissell PowerForce Compact Belt Replacement: adım 3, 3 resimden 2. Bissell PowerForce Compact Belt Replacement: adım 3, 3 resimden 3.
    • Grab the rotating brush at both ends.
    • Lift the rotating brush straight out of the vacuum.
    • Remove the belt from the motor pulley.
  4. Bissell PowerForce Compact Belt Replacement: adım 4, 2 resimden 1. Bissell PowerForce Compact Belt Replacement: adım 4, 2 resimden 2.
    • Clear the bottom of the vacuum from any debris that may be blocking air flow.
    • Clean the rotating brush from any wrapped string or hair. You can use scissors if needed.
  5. Bissell PowerForce Compact Belt Replacement: adım 5, 3 resimden 1. Bissell PowerForce Compact Belt Replacement: adım 5, 3 resimden 2. Bissell PowerForce Compact Belt Replacement: adım 5, 3 resimden 3.
    • Check the new belt for any damage.
    • Place the belt on the rotating brush and then the motor pulley.
  6. Bissell PowerForce Compact Belt Replacement: adım 6, 3 resimden 1. Bissell PowerForce Compact Belt Replacement: adım 6, 3 resimden 2. Bissell PowerForce Compact Belt Replacement: adım 6, 3 resimden 3.
    • Pull the rotating brush with the belt hooked.
    • Place the ends of the rotating brush into the slots.
    • Rotate the brush a few times to center the belt.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 46
Her zaman: 5,453
