Ana içeriğe geç
Bissell Powerglide Cordless Debris Canister Funnel Replacement
Neye ihtiyacın var
  1. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: adım 1, 3 resimden 1. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: adım 1, 3 resimden 2. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: adım 1, 3 resimden 3.
    • Remove the gray motor unit by twisting it so that the black triangle moves from the "locked" to the "unlocked" position.
  2. Bissell Powerglide Cordless Debris Canister Funnel Replacement: adım 2, 1 resimden 1.
    • Remove the filter from the dirt canister.
  3. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Debris Canister Funnel: adım 3, 1 resimden 1.
    • Separate the cyclone assembly from the dirt tank by twisting the pieces counterclockwise.
  4. Bissell Powerglide Cordless Debris Canister Funnel Replacement: adım 4, 1 resimden 1.
    • Use a Phillips head screwdriver to remove the three screws from the bottom of the cyclone assembly.
    • Remove the bottom of the assembly.
  5. Bissell Powerglide Cordless Debris Canister Funnel Replacement: adım 5, 2 resimden 1. Bissell Powerglide Cordless Debris Canister Funnel Replacement: adım 5, 2 resimden 2.
    • Twist the clear plastic capsule with the fins counterclockwise to remove it.
  6. Bissell Powerglide Cordless Debris Canister Funnel Replacement: adım 6, 1 resimden 1.
    • Twist the blue parts counterclockwise with a good amount of force to remove them.
Sonuç
Joseph Adam Johnson
511 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G2, Banghart Winter 2018 Cal Poly, Team S21-G2, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S21G2
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 205
