Ana içeriğe geç
Bissell SmartClean 1605 Roller Brush Replacement
Neye ihtiyacın var
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: adım 1, 1 resimden 1.
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: adım 2, 1 resimden 1.
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: adım 3, 3 resimden 1. Bissell SmartClean 1605 Roller Brush Replacement: adım 3, 3 resimden 2. Bissell SmartClean 1605 Roller Brush Replacement: adım 3, 3 resimden 3.
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: adım 4, 2 resimden 1. Bissell SmartClean 1605 Roller Brush Replacement: adım 4, 2 resimden 2.
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
Sonuç
Austin Maranville
117 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G4, Banghart Fall 2017 Cal Poly, Team S7-G4, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S7G4
5 Üyeler
5 adet Kılavuz yazıldı
13 Yorum
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - Yanıt
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - Yanıt
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - Yanıt
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 1,025
