Ana içeriğe geç
Giriş
This is a guide on how to replace the spiral brushing system on a bissell spotbot pet. Use this if your spiral brushing system is not working properly.
Parçalar
Hiçbir parça belirtilmedi.
  1. Bissell SpotBot Pet Control Panel Replacement, Control Panel: adım 1, 1 resimden 1.
    • Start here.
  2. Bissell SpotBot Pet Control Panel Replacement: adım 2, 1 resimden 1.
    • Remove the container on the right side of the vacuum.
  3. Bissell SpotBot Pet Control Panel Replacement: adım 3, 2 resimden 1. Bissell SpotBot Pet Control Panel Replacement: adım 3, 2 resimden 2.
    • Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum.
  4. Bissell SpotBot Pet Control Panel Replacement: adım 4, 1 resimden 1.
    • Remove the left container of the vacuum.
  5. Bissell SpotBot Pet Control Panel Replacement: adım 5, 1 resimden 1.
    • Remove the four screws on the top of the device.
  6. Bissell SpotBot Pet Control Panel Replacement: adım 6, 1 resimden 1.
    • Lift the top of the device off once the screws are removed.
  7. Bissell SpotBot Pet Control Panel Replacement: adım 7, 1 resimden 1.
    • Unplug the ribbon cable from the motherboard.
  8. Bissell SpotBot Pet Control Panel Replacement: adım 8, 1 resimden 1.
    • Separate the top piece and flip it upside down.
  9. Bissell SpotBot Pet Control Panel Replacement: adım 9, 2 resimden 1. Bissell SpotBot Pet Control Panel Replacement: adım 9, 2 resimden 2.
    • Remove the screws holding the motherboard in place.
  10. Bissell SpotBot Pet Control Panel Replacement: adım 10, 2 resimden 1. Bissell SpotBot Pet Control Panel Replacement: adım 10, 2 resimden 2.
    • Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Anthony Bonvino
437 İtibar
2 adet Kılavuz yazıldı
Cal Poly, Team S7-G3, Banghart Fall 2017 Cal Poly, Team S7-G3, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S7G3
4 Üyeler
4 adet Kılavuz yazıldı
One Comment
Where can I buy the part?
Sue Loberger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 371
