Ana içeriğe geç
Giriş
This is a guide on how to replace the spiral brushing system on a bissell spotbot pet. Use this if your spiral brushing system is not working properly.
Parçalar
Hiçbir parça belirtilmedi.
  1. Start here.
    • Start here.
    note to ifixit: we cannot edit the titles of each step
    Anthony Bonvino - Yanıt
  2. Remove the container on the right side of the vacuum.
    • Remove the container on the right side of the vacuum.
  3. Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum. Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum.
    • Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum.
  4. Remove the left container of the vacuum.
    • Remove the left container of the vacuum.
  5. Remove the four screws on the top of the device.
    • Remove the four screws on the top of the device.
  6. Lift the top of the device off once the screws are removed.
    • Lift the top of the device off once the screws are removed.
  7. Unplug the ribbon cable from the motherboard.
    • Unplug the ribbon cable from the motherboard.
  8. Separate the top piece and flip it upside down.
    • Separate the top piece and flip it upside down.
  9. Remove the screws holding the motherboard in place. Remove the screws holding the motherboard in place.
    • Remove the screws holding the motherboard in place.
  10. Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty. Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty.
    • Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Anthony Bonvino
425 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team S7-G3, Banghart Fall 2017 Cal Poly, Team S7-G3, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S7G3
4 Üyeler
Bir Yorum
Where can I buy the part?
Sue Loberger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 264
