Ana içeriğe geç
Bissell SpotBot Pet Repair Brush Motor Replacement
Neye ihtiyacın var
  1. Bissell SpotBot Pet Repair Brush Motor Replacement, Brush Motor: adım 1, 1 resimden 1.
    • First, set your Bissell SpotBot Pet on a flat surface to begin your repair.
  2. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 2, 1 resimden 1.
    • Lift the right container vertically to remove it from the vacuum.
  3. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 3, 2 resimden 1. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 3, 2 resimden 2.
    • Gently lift up the tab on the top of the vacuum and then proceed to lift the left container straight up to release it.
  4. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 4, 1 resimden 1.
    • Remove the tube from the vacuum by sliding the tube out of its holder on the side.
  5. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 5, 2 resimden 1. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 5, 2 resimden 2.
    • Unscrew the 4 screws on the top of the device and gently lift the top half up.
    • A ribbon cable is still attached to the underside of the top half.
  6. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 6, 3 resimden 1. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 6, 3 resimden 2. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 6, 3 resimden 3.
    • Unplug the ribbon cable that connects the bottom half to the control panel on the top half. Then, set the top half off to the side.
  7. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 7, 2 resimden 1. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 7, 2 resimden 2.
    • Unscrew the screw next to the white plastic wiring harness box. This will then allow you to set the white box off to the side.
  8. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 8, 1 resimden 1.
    • Unscrew the screws on the plastic holder on the right side of the device. Once this is done, remove the plastic holder from the vacuum.
    • Unscrew the screws that mount the vacuum motor to the device as shown.
  9. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 9, 2 resimden 1. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 9, 2 resimden 2.
    • Unplug the wires by disconnecting the section that connects the motor to the wiring harness.
  10. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 10, 2 resimden 1. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 10, 2 resimden 2.
    • Lift the white suction motor from the right side of the device. Lift it straight up and set it off to the side of the vacuum.
  11. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 11, 2 resimden 1. Bissell SpotBot Pet Repair Brush Motor Replacement: adım 11, 2 resimden 2.
    • Unscrew the screws for the brush motor as shown, this motor controls the automatic scrubbing mechanism.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Anthony Bonvino
437 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G3, Banghart Fall 2017 Cal Poly, Team S7-G3, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S7G3
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
hi i think you did an amazing job of breaking down how to disasemble this spotbot. i have the exact same one and though it works great suction is amazing, the brushes dont spin and i took it apart completely except i didnt know where the motor was that controlled the brushes until reading this. thanks so much
art - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,433
