Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
First, set your Bissell SpotBot Pet on a flat surface to begin your repair.
Lift the right container vertically to remove it from the vacuum.
Gently lift up the tab on the top of the vacuum and then proceed to lift the left container straight up to release it.
Remove the tube from the vacuum by sliding the tube out of its holder on the side.
Unscrew the 4 screws on the top of the device and gently lift the top half up.
Unplug the ribbon cable that connects the bottom half to the control panel on the top half. Then, set the top half off to the side.
Unscrew the screw next to the white plastic wiring harness box. This will then allow you to set the white box off to the side.
Unscrew the screws on the plastic holder on the right side of the device. Once this is done, remove the plastic holder from the vacuum.
Unscrew the screws that mount the vacuum motor to the device as shown.
Unplug the wires by disconnecting the section that connects the motor to the wiring harness.
Lift the white suction motor from the right side of the device. Lift it straight up and set it off to the side of the vacuum.
Unscrew the screws for the brush motor as shown, this motor controls the automatic scrubbing mechanism.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
hi i think you did an amazing job of breaking down how to disasemble this spotbot. i have the exact same one and though it works great suction is amazing, the brushes dont spin and i took it apart completely except i didnt know where the motor was that controlled the brushes until reading this. thanks so much
