Ana içeriğe geç
Bissell SpotClean ProHeat 5207U Float Stack Replacement
  1. Bissell SpotClean ProHeat 5207U Float Stack Replacement, Float Stack: adım 1, 1 resimden 1.
    • Ensure Bissell SpotClean ProHeat is unplugged.
    • Position your hand vacuum so that you can see the text at the bottom saying "SpotClean ProHeat."
  2. Bissell SpotClean ProHeat 5207U Float Stack Replacement: adım 2, 2 resimden 1. Bissell SpotClean ProHeat 5207U Float Stack Replacement: adım 2, 2 resimden 2.
    • Remove the dirty water tank. It is the tank on the right.
    • The tank reads "dirty" on the bottom on the inner edge.
  3. Bissell SpotClean ProHeat 5207U Float Stack Replacement: adım 3, 3 resimden 1. Bissell SpotClean ProHeat 5207U Float Stack Replacement: adım 3, 3 resimden 2. Bissell SpotClean ProHeat 5207U Float Stack Replacement: adım 3, 3 resimden 3.
    • Rotate the bottom of the float stack counterclockwise until the float stack comes lose.
    • Remove the float stack from the tank.
  4. Bissell SpotClean ProHeat 5207U Float Stack Replacement: adım 4, 3 resimden 1. Bissell SpotClean ProHeat 5207U Float Stack Replacement: adım 4, 3 resimden 2. Bissell SpotClean ProHeat 5207U Float Stack Replacement: adım 4, 3 resimden 3.
    • Grab the float on the float Stack assembly
    • Slide the float down towards the base.
    • Remove float and clean any debris found.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Edy Mendoza
422 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 169
