Ana içeriğe geç
Bissell SpotClean ProHeat 5207U Hose Replacement
Neye ihtiyacın var
  1. Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: adım 1, 2 resimden 1. Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: adım 1, 2 resimden 2.
    • Ensure Bissell SpotClean ProHeat is unplugged
    • Position your hand vacuum so that you can see the text at the bottom saying "SpotClean ProHeat."
    • Remove the dirty water tank and the clean water tank that are located on either side.
  2. Bissell SpotClean ProHeat 5207U Hose Replacement: adım 2, 3 resimden 1. Bissell SpotClean ProHeat 5207U Hose Replacement: adım 2, 3 resimden 2. Bissell SpotClean ProHeat 5207U Hose Replacement: adım 2, 3 resimden 3.
    • Turn the device so that the bottom is facing up.
    • Remove the marked 19.7 mm screws using the Phillips #00 screwdriver to remove the plastic covering.
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three screws located under the plastic cover that was previously removed.
  3. Bissell SpotClean ProHeat 5207U Hose Replacement: adım 3, 2 resimden 1. Bissell SpotClean ProHeat 5207U Hose Replacement: adım 3, 2 resimden 2.
    • Remove the plastic lip that was previously held by the screws.
    • Remove the 17.2 mm screws using the Phillips #00 Screwdriver to gain access to the water pump.
  4. Bissell SpotClean ProHeat 5207U Hose Replacement: adım 4, 2 resimden 1. Bissell SpotClean ProHeat 5207U Hose Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to to squeeze together the prongs of the hose clamp.
    • With the clamp squeezed, pull the hose from the pump.
    • We found it easier to pull the clamp up the hose then pull the hose from the pump.
  5. Bissell SpotClean ProHeat 5207U Hose Replacement: adım 5, 1 resimden 1.
    • Pull the hose from the opposite end of the pump until it is fully removed.
    • Replace the previous non-working hose with a new working hose.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 123
Her zaman: 567
