Giriş
Is your Bissell SpotClean ProHeat 5207U spray trigger difficult to use? It could be because of a failing spray mechanism. Follow this guide to replace the spray mechanism for your Bissell SpotClean ProHeat 5207U.
Neye ihtiyacın var
Place the brush in front of you and make sure that the brushes are rotated towards the ceiling.
Separate the brush from the hose by pressing the lever.
Bu adımda kullanılan alet:Tweezers$4.99
Using tweezers, squeeze the hose clamp prongs together to loosen it.
As you are squeezing the hose clamp prongs, pull the spraying mechanism out to remove it.
Once the spraying mechanism is removed, and squeeze the clamp prongs again and install the new mechanism.
2 farklı kişi bu kılavuzu tamamladı.
