Ana içeriğe geç
Bissell SpotClean ProHeat 5207U Water Pump Replacement
Neye ihtiyacın var
  1. Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: adım 1, 2 resimden 1. Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: adım 1, 2 resimden 2.
    • Ensure the device is unplugged.
    • Make sure that you have removed both the clean and dirty water tank so that you can unscrew the proper screws.
    • Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
  2. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 2, 3 resimden 1. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 2, 3 resimden 2. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 2, 3 resimden 3.
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three 17.2 mm screws.
    • Remove the plastic lip that was previously held by the screws.
  3. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 3, 2 resimden 1. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 3, 2 resimden 2.
    • Using pliers, pinch the hose clamp tabs together, then remove the clamp.
    • Remove the water hose from the water pump.
  4. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 4, 2 resimden 1. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 4, 2 resimden 2.
    • Remove the green wire by pulling it away from the pump.
    • Be careful not to bend where the wire is plugged into.
  5. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 5, 2 resimden 1. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 5, 2 resimden 2.
    • Pull the clear hose away from the pump until it is removed.
  6. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 6, 2 resimden 1. Bissell SpotClean ProHeat 5207U Water Pump Replacement: adım 6, 2 resimden 2.
    • Remove the zip tie from the water pump.
    • Replace the old water pump with the new water pump.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 153
