Ana içeriğe geç
Bissell Swivel Rewind Pet Vacuum Belt Replacement
Neye ihtiyacın var
  1. Bissell Swivel Rewind Pet Vacuum Belt Replacement, Belt: adım 1, 3 resimden 1. Bissell Swivel Rewind Pet Vacuum Belt Replacement, Belt: adım 1, 3 resimden 2. Bissell Swivel Rewind Pet Vacuum Belt Replacement, Belt: adım 1, 3 resimden 3.
    • Using your Phillips #2 screwdriver, remove the six 17.5 mm screws on the front panel that holds the brush roll in place.
  2. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 2, 3 resimden 1. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 2, 3 resimden 2. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 2, 3 resimden 3.
    • Pull the front panel to remove it and access the brush roll and the broken belt.
  3. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 3, 3 resimden 1. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 3, 3 resimden 2. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 3, 3 resimden 3.
    • Remove the broken belt.
    • Hold the brush roll on both ends and pull it outward to remove it.
  4. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 4, 2 resimden 1. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 4, 2 resimden 2.
    • Put the new belt on the metal that makes the belt turn. It is located close to the rear tire.
  5. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 5, 2 resimden 1. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 5, 2 resimden 2.
    • Put the new belt on the brush roll where there is a black spot.
  6. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 6, 2 resimden 1. Bissell Swivel Rewind Pet Vacuum Belt Replacement: adım 6, 2 resimden 2.
    • Pull the brush roll upward and align it in its original spot.
    • This may take some force.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kouassi Kouassi
187 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
Ty but where do I buy the belt??
hysell64@gmail.com - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 46
Her zaman: 3,482
