Giriş
If any issues are arising inside your Bissell Zing 2156A, or you simply want to replace the casing, this guide will assist in taking it apart.
The casing is a extruded plastic shell, with other smaller plastic bits coming out of it. The casing is held in place by screws and small "snap-fit" fasteners. This guide starts with the removal of the rear wheel.
Overall, this assembly is safe to disassemble and reassemble.
Neye ihtiyacın var
Remove the dust tank, so the vacuum can lie upside down easily.
Press the grey button while pulling up.
Remove the two 18.1 mm screws using a Phillips #0 screwdriver.
Remove the four 18.1 mm screws under the wheels using a Phillips #0 screwdriver.
Bir başkası bu kılavuzu tamamladı.
