Ana içeriğe geç
Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly
Neye ihtiyacın var
  1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Lid and Bowl: adım 1, 1 resimden 1.
    • Make sure the device is unplugged before beginning disassembly!
    • Lift the lid and bowl from the top of the device.
  2. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Turn the Device Upside-Down: adım 2, 1 resimden 1.
    • Turn the device upside-down, so that the four legs of the device point upwards.
  3. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Rubber Cushions: adım 3, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Rubber Cushions: adım 3, 2 resimden 2.
    • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
  4. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Spanning Screw: adım 4, 1 resimden 1.
    • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
  5. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Leg Screws: adım 5, 1 resimden 1.
    • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
    • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
  6. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Brass Plate: adım 6, 1 resimden 1.
    • Lift the brass plate off the device and set it aside.
  7. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Color the Wires: adım 7, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Color the Wires: adım 7, 2 resimden 2.
    • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
    • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
    • Unscrew the screw at the junction near the opposite side of the device from the front panel.
    • Label each of the two wires at this junction with a single color of tape.
  8. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Label the Second Wire Junction: adım 8, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Label the Second Wire Junction: adım 8, 2 resimden 2.
    • Unscrew the screw at the junction just clockwise from the button panel.
    • Label the three wires of this junction with tape of a second color.
  9. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Label the Third Wire Junction: adım 9, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Label the Third Wire Junction: adım 9, 2 resimden 2.
    • Unscrew the screw from the wire junction just behind the front panel.
    • Label the three wires at this junction with a third color of tape.
  10. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Unlock and disconnect the Hotplate Latch: adım 10, 3 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Unlock and disconnect the Hotplate Latch: adım 10, 3 resimden 2. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Unlock and disconnect the Hotplate Latch: adım 10, 3 resimden 3.
    • Using a pair of pliers, bend the brass-colored beam poking through the hotplate's silver colored beam from a "(" shape into a "c" shape so it fits through the hole in the silver-colored beam.
    • Push the brass beam down and pull the silver beam up to disconnect the two beams.
  11. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Unscrew the Hotplate: adım 11, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Unscrew the Hotplate: adım 11, 2 resimden 2.
    • Unscrew the four 10mm long 7mm diameter Phillips screws attached to the hotplate.
  12. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Hotplate: adım 12, 1 resimden 1.
    • Carefully lift up the device, either by allowing the hotplate portion to fall out while it is close to the ground, or by catching the hotplate portion as it slides out.
  13. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Unlock the Front Panel: adım 13, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Unlock the Front Panel: adım 13, 2 resimden 2.
    • Turn the rice cooker so that the front panel is facing down and you have a good view of the inside.
    • Remove the one 8mm long 9mm diameter Phillips screw just above the inside of the front panel.
  14. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Position the Panel: adım 14, 1 resimden 1.
    • Carefully pull the front panel out along with the silver-colored metal beam.
    • Lay the panel flat, with the silver-colored metal beam facing up.
  15. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Panels Backing the Lights: adım 15, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Panels Backing the Lights: adım 15, 2 resimden 2.
    • Unscrew the 6mm long 5mm diameter Phillips screw from whichever panel(s) correspond(s) to the light that was broken on the other side.
    • Remove the yellow panel(s) by lifting them off or turning the panel upside-down.
  16. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Expose the Light's Wire: adım 16, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Expose the Light's Wire: adım 16, 2 resimden 2.
    • For each broken lightbulb, expose the wire leading to the bulb by pulling back the plastic coating on the wire while gently holding onto the bulb.
  17. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Wire Insulation: adım 17, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Remove the Wire Insulation: adım 17, 2 resimden 2.
    • Using a pair of needlenose pliers or wire strippers, cut the rubber covering on each wire about 5 mm from the edge and pull away the remaining rubber from the light.
  18. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Disconnect the Light: adım 18, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Disconnect the Light: adım 18, 2 resimden 2.
    • Cut the wires close to the original light so that you will have more wire available for sautering in the next step.
    • Use a pair of wire cutters, diagonal pliers, or sharp scissors, cut the wires leading to the light.
  19. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Attach the New Light: adım 19, 2 resimden 1. Black and Decker 3-Cup Rice Cooker Light Bulb Disassembly, Attach the New Light: adım 19, 2 resimden 2.
    • Using a sautering iron, carefully sauter both wire ends of the new light bulb to the device's wires.
    • Make sure that the wires don't cross, as this will stop the light from working.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lillian Heng
679 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-1, Forte Fall 2014 Cal Poly, Team 12-1, Forte Fall 2014 üyesi
CPSU-FORTE-F14S12G1
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 5,539
