Ana içeriğe geç
Black and Decker BDEDMT Directional Switch Replacement
Neye ihtiyacın var
  1. Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: adım 1, 2 resimden 1. Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: adım 1, 2 resimden 2.
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: adım 2, 3 resimden 1. Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: adım 2, 3 resimden 2. Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: adım 2, 3 resimden 3.
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: adım 3, 2 resimden 1. Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: adım 3, 2 resimden 2.
    • Gently pull up on the trigger module.
    • Be sure to not loosen or disturb any wiring.
  4. Black and Decker BDEDMT Directional Switch Replacement: adım 4, 2 resimden 1. Black and Decker BDEDMT Directional Switch Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • With the trigger module out of the way you will then remove the metal piece that is located behind the directional switch and has the spring attached to it.
    • Do this by simply pulling up on the metal with your fingers or your tweezers.
    • Make sure to not loosen or remove the black trigger stopper.
  5. Black and Decker BDEDMT Directional Switch Replacement: adım 5, 2 resimden 1. Black and Decker BDEDMT Directional Switch Replacement: adım 5, 2 resimden 2.
    • The black directional switch can now be freely removed.
Sonuç
Tyler Yurina
419 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016 üyesi
UWT-ROSE-W16S1G2
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 370
