Ana içeriğe geç
Black and Decker BDEDMT Motor Replacement
Neye ihtiyacın var
  1. Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: adım 1, 2 resimden 1. Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: adım 1, 2 resimden 2.
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: adım 2, 3 resimden 1. Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: adım 2, 3 resimden 2. Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: adım 2, 3 resimden 3.
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Motor Replacement, Motor: adım 3, 1 resimden 1.
    • Gently pull up the motor and other components at the top of the device except the handle.
    • Watch out for the wires. They are connected to two compressed magnets in the black framework.
  4. Black and Decker BDEDMT Motor Replacement: adım 4, 2 resimden 1. Black and Decker BDEDMT Motor Replacement: adım 4, 2 resimden 2.
    • Slide off the the black framework on the barring side.
    • You may have to compress the magnets in order to slide the framework off of the barring.
  5. Black and Decker BDEDMT Motor Replacement: adım 5, 2 resimden 1. Black and Decker BDEDMT Motor Replacement: adım 5, 2 resimden 2.
    • Remove the release button attached at the front of the motor.
    • It may have already come off during Step 3.
  6. Black and Decker BDEDMT Motor Replacement: adım 6, 2 resimden 1. Black and Decker BDEDMT Motor Replacement: adım 6, 2 resimden 2.
    • Work the silver magnetic ring off of the motor through the barring end.
    • The motor is now free.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler Yurina
419 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016 üyesi
UWT-ROSE-W16S1G2
4 Üyeler
11 adet Kılavuz yazıldı
3 Yorum
Hi,
Please can you tell me where to find the motor replacement part for this tool?
Thank you
Renato - Yanıt
I have this tool and the attachments and I absolutely love it…but I'm pretty sure the gears are stripped…do you know anything about replacing those?
cwilson0713@gmail.com - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 57
Her zaman: 2,657
