Ana içeriğe geç
Black and Decker BDERO100 Chassis Replacement
Neye ihtiyacın var
  1. Black and Decker BDERO100 Chassis Replacement, Chassis: adım 1, 2 resimden 1. Black and Decker BDERO100 Chassis Replacement, Chassis: adım 1, 2 resimden 2.
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Chassis Replacement: adım 2, 2 resimden 1. Black and Decker BDERO100 Chassis Replacement: adım 2, 2 resimden 2.
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Chassis Replacement: adım 3, 2 resimden 1. Black and Decker BDERO100 Chassis Replacement: adım 3, 2 resimden 2.
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Chassis Replacement: adım 4, 2 resimden 1. Black and Decker BDERO100 Chassis Replacement: adım 4, 2 resimden 2.
    • Hold the chassis and separate it from the device.
Sonuç
Irene Zubillaga
617 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Spring 2016 USF Tampa, Team 1-5, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 453
