Ana içeriğe geç
Black and Decker BDERO100 Motor Replacement
Neye ihtiyacın var
  1. Black and Decker BDERO100 Motor Replacement, Hook and Loop System: adım 1, 1 resimden 1.
    • Remove the sanding paper from the velcro.
  2. Black and Decker BDERO100 Motor Replacement: adım 2, 1 resimden 1.
    • Select the JIS - J1 bit or the most appropriate bit to match the screws for your model.
  3. Black and Decker BDERO100 Motor Replacement: adım 3, 2 resimden 1. Black and Decker BDERO100 Motor Replacement: adım 3, 2 resimden 2.
    • Use the Bit Driver to take off the four 12.5 mm Phillips screws at the base of the hook-and-loop system.
    • Be careful not to lose the lock washers (black rings).
  4. Black and Decker BDERO100 Motor Replacement: adım 4, 2 resimden 1. Black and Decker BDERO100 Motor Replacement: adım 4, 2 resimden 2.
    • Once all screws and washers have been removed, hold the hook and loop system and separate it from the device.
  5. Black and Decker BDERO100 Motor Replacement, Chassis: adım 5, 2 resimden 1. Black and Decker BDERO100 Motor Replacement, Chassis: adım 5, 2 resimden 2.
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  6. Black and Decker BDERO100 Motor Replacement: adım 6, 2 resimden 1. Black and Decker BDERO100 Motor Replacement: adım 6, 2 resimden 2.
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  7. Black and Decker BDERO100 Motor Replacement: adım 7, 2 resimden 1. Black and Decker BDERO100 Motor Replacement: adım 7, 2 resimden 2.
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  8. Black and Decker BDERO100 Motor Replacement: adım 8, 2 resimden 1. Black and Decker BDERO100 Motor Replacement: adım 8, 2 resimden 2.
    • Hold the chassis and separate it from the device.
  9. Black and Decker BDERO100 Motor Replacement, Motor: adım 9, 3 resimden 1. Black and Decker BDERO100 Motor Replacement, Motor: adım 9, 3 resimden 2. Black and Decker BDERO100 Motor Replacement, Motor: adım 9, 3 resimden 3.
    • Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
  10. Black and Decker BDERO100 Motor Replacement: adım 10, 2 resimden 1. Black and Decker BDERO100 Motor Replacement: adım 10, 2 resimden 2.
    • With yout hands, hold and separate the power button from the external case by pulling gently.
  11. Black and Decker BDERO100 Motor Replacement: adım 11, 2 resimden 1. Black and Decker BDERO100 Motor Replacement: adım 11, 2 resimden 2.
    • Hold the motor and gently pull to remove from chassis.
  12. Black and Decker BDERO100 Motor Replacement: adım 12, 3 resimden 1. Black and Decker BDERO100 Motor Replacement: adım 12, 3 resimden 2. Black and Decker BDERO100 Motor Replacement: adım 12, 3 resimden 3.
    • Gently pull on all cables connected to the motor to remove.
  13. Black and Decker BDERO100 Motor Replacement: adım 13, 2 resimden 1. Black and Decker BDERO100 Motor Replacement: adım 13, 2 resimden 2.
    • Once all cables are disconnected, you can proceed to replace the motor.
Sonuç
Irene Zubillaga
617 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Spring 2016 USF Tampa, Team 1-5, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G5
4 Üyeler
6 adet Kılavuz yazıldı
1 Guide Comment
Hey, I’m planning on changing the motor on my B+D 20V Sander and it seems to be the same (or at least very similar) procedure, but I’d like to know the type of motor it needs. Do you know how can I know the specs of the motor? or is that more of a open and see kind of thing?
Thanks!
Diego Alejandro, Avilan Franco - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 1,762
