Ana içeriğe geç
Black and Decker BDERO100 Power Button Replacement
Neye ihtiyacın var
  1. Black and Decker BDERO100 Power Button Replacement, Chassis: adım 1, 2 resimden 1. Black and Decker BDERO100 Power Button Replacement, Chassis: adım 1, 2 resimden 2.
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Power Button Replacement: adım 2, 2 resimden 1. Black and Decker BDERO100 Power Button Replacement: adım 2, 2 resimden 2.
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Power Button Replacement: adım 3, 2 resimden 1. Black and Decker BDERO100 Power Button Replacement: adım 3, 2 resimden 2.
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Power Button Replacement: adım 4, 2 resimden 1. Black and Decker BDERO100 Power Button Replacement: adım 4, 2 resimden 2.
    • Hold the chassis and separate it from the device.
  5. Black and Decker BDERO100 Power Button Replacement, Power Button: adım 5, 2 resimden 1. Black and Decker BDERO100 Power Button Replacement, Power Button: adım 5, 2 resimden 2.
    • Hold the power button and pull it out of the chassis.
  6. Black and Decker BDERO100 Power Button Replacement: adım 6, 2 resimden 1. Black and Decker BDERO100 Power Button Replacement: adım 6, 2 resimden 2.
    • Select the cable that connects to the power button.
  7. Black and Decker BDERO100 Power Button Replacement: adım 7, 1 resimden 1.
    • Expose the cable and lock system by peeling off the electric cover.
    • When attaching the new power cord you will need to make sure to cover this lock system with electrical tape.
  8. Black and Decker BDERO100 Power Button Replacement: adım 8, 2 resimden 1. Black and Decker BDERO100 Power Button Replacement: adım 8, 2 resimden 2.
    • Push the security pin with the plastic spudger and simultaneously, pull gently on the cable to separate it from the button
  9. Black and Decker BDERO100 Power Button Replacement: adım 9, 2 resimden 1. Black and Decker BDERO100 Power Button Replacement: adım 9, 2 resimden 2.
    • Detach the black wire connected to the power button from the motor. To do this, gently pull the cable while holding the power button.
Sonuç
Irene Zubillaga
617 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Spring 2016 USF Tampa, Team 1-5, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,143
