Ana içeriğe geç
Black and Decker BDH9600CHV Filter Button Replacement
Neye ihtiyacın var
  1. Black and Decker BDH9600CHV Filter Button Replacement, Filter Button: adım 1, 3 resimden 1. Black and Decker BDH9600CHV Filter Button Replacement, Filter Button: adım 1, 3 resimden 2. Black and Decker BDH9600CHV Filter Button Replacement, Filter Button: adım 1, 3 resimden 3.
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Filter Button Replacement: adım 2, 1 resimden 1.
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Filter Button Replacement: adım 3, 2 resimden 1. Black and Decker BDH9600CHV Filter Button Replacement: adım 3, 2 resimden 2.
    • Pull the housing apart.
    • Note when the housing is taken apart some parts may fall out be sure to keep track of any parts that come out.
    • Remove the filter button by pulling it out.
  4. Black and Decker BDH9600CHV Filter Button Replacement: adım 4, 1 resimden 1.
    • Replace the new button by compressing the spring and placing it in the groove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ivette Muzquiz
349 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Harley Fall 2017 IUPUI, Team S1-G4, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S1G4
3 Üyeler
Bir Yorum
After a year of very light use, it was working great. Now I have been facing some troublesome it’s shutting down frequently as like after about a minute. I bought a new filter and it is still shut down. Kept on the charger all the time. Do you have any idea actually what is going wrong with it? Or do you have any suggestion which would be best for pet hair?
Alexis Martinovich - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 551
