Ana içeriğe geç
Black and Decker BDH9600CHV Motor Replacement
Neye ihtiyacın var
  1. Black and Decker BDH9600CHV Motor Replacement, Motor: adım 1, 3 resimden 1. Black and Decker BDH9600CHV Motor Replacement, Motor: adım 1, 3 resimden 2. Black and Decker BDH9600CHV Motor Replacement, Motor: adım 1, 3 resimden 3.
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Motor Replacement: adım 2, 1 resimden 1.
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Motor Replacement: adım 3, 3 resimden 1. Black and Decker BDH9600CHV Motor Replacement: adım 3, 3 resimden 2. Black and Decker BDH9600CHV Motor Replacement: adım 3, 3 resimden 3.
    • Pull the housing apart
    • When you pull apart the housing pieces could fall out. Be sure to keep track of them.
    • Remove the motor unit from the housing
    • Note that the black disk needs to be firmly pulled it will resist, but can be pulled directly off of the pin if it is pulled hard enough.
  4. Black and Decker BDH9600CHV Motor Replacement: adım 4, 3 resimden 1. Black and Decker BDH9600CHV Motor Replacement: adım 4, 3 resimden 2. Black and Decker BDH9600CHV Motor Replacement: adım 4, 3 resimden 3.
    • Remove the motor from the circuit board.
    • The motor makes contact with the board at 2 points. These may be bent or distorted. Straighten them with a pair of needle nose pliers in order to remove.
Sonuç
Ivette Muzquiz
349 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Harley Fall 2017 IUPUI, Team S1-G4, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 2,306
