Ana içeriğe geç
Black and Decker BDH9600CHV Power Switch Replacement
Neye ihtiyacın var
  1. Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: adım 1, 3 resimden 1. Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: adım 1, 3 resimden 2. Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: adım 1, 3 resimden 3.
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Power Switch Replacement: adım 2, 1 resimden 1.
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Power Switch Replacement: adım 3, 2 resimden 1. Black and Decker BDH9600CHV Power Switch Replacement: adım 3, 2 resimden 2.
    • Pull the housing apart.
    • When you pull the housing apart, pieces may fall out. Be sure to track of the parts and where they go.
    • Remove the switch by pulling it out.
  4. Black and Decker BDH9600CHV Power Switch Replacement: adım 4, 2 resimden 1. Black and Decker BDH9600CHV Power Switch Replacement: adım 4, 2 resimden 2.
    • Replace the new switch by sliding the replacement switch onto the top of the switch mechanism located on the motor.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ivette Muzquiz
349 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Harley Fall 2017 IUPUI, Team S1-G4, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S1G4
3 Üyeler
Bir Yorum
My switch with up & down button box like
Fernando Palacios - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,127
