Ana içeriğe geç
Black and Decker BL3000S Circuit Board
Neye ihtiyacın var
  1. Black and Decker BL3000S Circuit Board, Blender Base: adım 1, 2 resimden 1. Black and Decker BL3000S Circuit Board, Blender Base: adım 1, 2 resimden 2.
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Circuit Board: adım 2, 1 resimden 1.
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Circuit Board: adım 3, 2 resimden 1. Black and Decker BL3000S Circuit Board: adım 3, 2 resimden 2.
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Circuit Board: adım 4, 1 resimden 1.
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Circuit Board: adım 5, 1 resimden 1.
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Circuit Board, Circuit Board: adım 6, 1 resimden 1.
    • Once you have the base removed, the circuit board should be clearly visible inside.
  7. Black and Decker BL3000S Circuit Board: adım 7, 2 resimden 1. Black and Decker BL3000S Circuit Board: adım 7, 2 resimden 2.
    • Remove the four screws located on the circuit board.
    • Two are on the left side.
    • Two are on the right side.
  8. Black and Decker BL3000S Circuit Board: adım 8, 1 resimden 1.
    • Remove the following soldered connections with a soldering iron:
    • Motor wires
    • Power cord wires
  9. Black and Decker BL3000S Circuit Board: adım 9, 1 resimden 1.
    • Lift the circuit board straight up to remove it from the base.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew
209 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G34
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 46
Her zaman: 4,700
