Ana içeriğe geç
Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement
Neye ihtiyacın var
  1. Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement, Clamshell (Black Outer Casing): adım 1, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement: adım 2, 2 resimden 1. Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement: adım 2, 2 resimden 2.
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
Sonuç
Angelica Chow
409 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-29, Maness Winter 2014 Cal Poly, Team 9-29, Maness Winter 2014 üyesi
CPSU-MANESS-W14S9G29
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 735
