Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will take you through the process of replacing the power cord on the Black and Decker BV2500 Type 4. Without a power cord that works, the device will not turn on.
Neye ihtiyacın var
Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
Use your hands to lift off the side of the orange casing with the screws facing you.
