Ana içeriğe geç
Black and Decker CM0700BZ Power Button Replacement
Neye ihtiyacın var
  1. Black and Decker CM0700BZ Power Button Replacement, Power Button: adım 1, 2 resimden 1. Black and Decker CM0700BZ Power Button Replacement, Power Button: adım 1, 2 resimden 2.
    • Ensure power cord is unplugged from the wall.
    • Remove the carafe holder from the bottom of the coffee machine.
  2. Black and Decker CM0700BZ Power Button Replacement: adım 2, 3 resimden 1. Black and Decker CM0700BZ Power Button Replacement: adım 2, 3 resimden 2. Black and Decker CM0700BZ Power Button Replacement: adım 2, 3 resimden 3.
    • Place coffee maker on its side, with the bottom facing you.
    • Remove the two 10 mm Phillips #1 screws.
    • Remove one 10 mm Tri-Point Y1 screw.
  3. Black and Decker CM0700BZ Power Button Replacement: adım 3, 3 resimden 1. Black and Decker CM0700BZ Power Button Replacement: adım 3, 3 resimden 2. Black and Decker CM0700BZ Power Button Replacement: adım 3, 3 resimden 3.
    • Slowly pry the bottom lid from the front.
    • You should hear a pop.
    • Pull up and remove the bottom lid.
  4. Black and Decker CM0700BZ Power Button Replacement: adım 4, 3 resimden 1. Black and Decker CM0700BZ Power Button Replacement: adım 4, 3 resimden 2. Black and Decker CM0700BZ Power Button Replacement: adım 4, 3 resimden 3.
    • Using a screwdriver or spudger, firmly press on the middle of heat shrink and pull each electrical connection apart.
    • Gently push the power button out of the housing while pushing the tabs inwards.
  5. Black and Decker CM0700BZ Power Button Replacement: adım 5, 3 resimden 1. Black and Decker CM0700BZ Power Button Replacement: adım 5, 3 resimden 2. Black and Decker CM0700BZ Power Button Replacement: adım 5, 3 resimden 3.
    • Use a screwdriver or spudger to pry out the power button.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ramez Gerges
124 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Shaddix Spring 2023 UMass Dartmouth, Team 1-2, Shaddix Spring 2023 üyesi
UMASSD-SHADDIX-S23S1G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 74
Her zaman: 695
