Ana içeriğe geç
Black and Decker CM0700BZ Shower Head Replacement
Neye ihtiyacın var
  1. Black and Decker CM0700BZ Shower Head Replacement, Shower Head: adım 1, 2 resimden 1. Black and Decker CM0700BZ Shower Head Replacement, Shower Head: adım 1, 2 resimden 2.
    • Open the lid of the coffee maker.
    • Remove the brew cup.
  2. Black and Decker CM0700BZ Shower Head Replacement: adım 2, 3 resimden 1. Black and Decker CM0700BZ Shower Head Replacement: adım 2, 3 resimden 2. Black and Decker CM0700BZ Shower Head Replacement: adım 2, 3 resimden 3.
    • Place your finger, a screwdriver, or a spudger behind the corner of the tab.
    • Pull up on the tab until it disconnects from the coffee maker.
  3. Black and Decker CM0700BZ Shower Head Replacement: adım 3, 3 resimden 1. Black and Decker CM0700BZ Shower Head Replacement: adım 3, 3 resimden 2. Black and Decker CM0700BZ Shower Head Replacement: adım 3, 3 resimden 3.
    • Push the lid while holding the tab.
    • The lid should open fully with the top of the lid facing down.
  4. Black and Decker CM0700BZ Shower Head Replacement: adım 4, 2 resimden 1. Black and Decker CM0700BZ Shower Head Replacement: adım 4, 2 resimden 2.
    • Lift up the shower head while the lid is lying flat.
    • Squeeze the tabs together until one peg comes loose from the insert.
    • Pull the other peg from the insert and remove the shower head from the lid.
Sonuç
Shawn Robichaud
729 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Shaddix Spring 2023 UMass Dartmouth, Team 1-2, Shaddix Spring 2023 üyesi
UMASSD-SHADDIX-S23S1G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 222
