Ana içeriğe geç
Black and Decker DCM100R Heating Element Replacement
Neye ihtiyacın var
  1. Black and Decker DCM100R Heating Element Replacement, Heating Element: adım 1, 2 resimden 1. Black and Decker DCM100R Heating Element Replacement, Heating Element: adım 1, 2 resimden 2.
    • Turn the coffee maker on its side.
    • Remove the four 6 mm Phillips #2 that secure the baseplate.
  2. Black and Decker DCM100R Heating Element Replacement: adım 2, 3 resimden 1. Black and Decker DCM100R Heating Element Replacement: adım 2, 3 resimden 2. Black and Decker DCM100R Heating Element Replacement: adım 2, 3 resimden 3.
    • Insert the jimmy at the back of the panel and slide it around to the front.
  3. Black and Decker DCM100R Heating Element Replacement: adım 3, 3 resimden 1. Black and Decker DCM100R Heating Element Replacement: adım 3, 3 resimden 2. Black and Decker DCM100R Heating Element Replacement: adım 3, 3 resimden 3.
    • Apply pressure to the backside of the panel until it releases.
    • Remove the plate.
  4. Black and Decker DCM100R Heating Element Replacement: adım 4, 2 resimden 1. Black and Decker DCM100R Heating Element Replacement: adım 4, 2 resimden 2.
    • Remove the two 10 mm Phillips #2 screws securing the metal support brace.
    • Remove the brace and set aside.
  5. Black and Decker DCM100R Heating Element Replacement: adım 5, 2 resimden 1. Black and Decker DCM100R Heating Element Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Pull back the tubing and wiring to reveal the hot plate.
    • To hold these out of your way, you can use the Nylon Tipped Tweezers to pin them back to the back panel.
  6. Black and Decker DCM100R Heating Element Replacement: adım 6, 2 resimden 1. Black and Decker DCM100R Heating Element Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the five 8 mm screws that secure the mounting bracket and hot plate.
  7. Black and Decker DCM100R Heating Element Replacement: adım 7, 2 resimden 1. Black and Decker DCM100R Heating Element Replacement: adım 7, 2 resimden 2.
    • Use a pair of pliers to gently pull the mounting bracket out of place.
  8. Black and Decker DCM100R Heating Element Replacement: adım 8, 3 resimden 1. Black and Decker DCM100R Heating Element Replacement: adım 8, 3 resimden 2. Black and Decker DCM100R Heating Element Replacement: adım 8, 3 resimden 3.
    • Remove the hot plate from the mounting bracket.
    • Remove the O-ring from the hot plate.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 152
