Ana içeriğe geç
Black and Decker DustBuster 15.6V Battery Pack Replacement
Neye ihtiyacın var
  1. Black and Decker DustBuster 15.6V Battery Pack Replacement, Battery Pack: adım 1, 2 resimden 1. Black and Decker DustBuster 15.6V Battery Pack Replacement, Battery Pack: adım 1, 2 resimden 2.
    • Remove the six exterior 2 mm Phillips #0 screws securing the 2 halves of the white shell together.
  2. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 2, 2 resimden 1. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 2, 2 resimden 2.
    • Remove nozzle by pressing two blue buttons on the side of the nozzle
  3. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 3, 2 resimden 1. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 3, 2 resimden 2.
    • Remove the dustbin by pressing the blue button on the vacuum's handle and lift the bin from the vacuum.
  4. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 4, 3 resimden 1. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 4, 3 resimden 2. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 4, 3 resimden 3.
    • Gently separate the two halves by pulling them apart, revealing the 14 cell battery pack behind the motor.
  5. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 5, 2 resimden 1. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 5, 2 resimden 2.
    • Removal of the battery pack is a tool-less process, lift the battery pack out of the vacuum gently, notice there are two wires connected to the battery.
  6. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 6, 2 resimden 1. Black and Decker DustBuster 15.6V Battery Pack Replacement: adım 6, 2 resimden 2.
    • Disconnect the red wire from the battery pack (pull do not twist!) and do the same with the black wire
Sonuç
31 farklı kişi bu kılavuzu tamamladı.
Jordon Borges
1.053 İtibar
2 adet Kılavuz yazıldı
Ekip
24 Yorum
I am having trouble finding replacement battery pack for purchase. Any suggestions?
jjragin - Yanıt
Replace the ni-cad pack with a li-ion one. 4 each 18650 cells will give you 14.8vdc. If you use/buy a computer battery you’ll have enough cells for 2 repairs. Get the highest capacity cells you can, i.e. 2.6ahr or higher. Solder them all in series, charge it up and listen to it SCREEM. Works for me. (Reason for computer battery is the quality of the cells and they have tabs to solder to) mikey
Mike - Yanıt
There is a resistor there so the higher voltage will cause the resistor to melt. Did you receive your EE tech degree at an ITT school?
wer werwerwer - Yanıt
Was it a resister or a fuse? Just asking. Some small appliances have a safety fuse that resembles a resister.
herring - Yanıt
Whatever the componentry there is always a reasonable overvoltage margin. Mikes post should be fine.
Lawrence Hughes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 30
Son 7 gün: 156
Son 30 gün: 946
Her zaman: 105,274
