Ana içeriğe geç
Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement
Neye ihtiyacın var
  1. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement, Suction Rubber Seal: adım 1, 1 resimden 1.
    • Press to blue unlock buttons at the base of the nozzle in word and pull forward .
  2. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: adım 2, 1 resimden 1.
    • Locate rubber suction seal.
  3. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: adım 3, 1 resimden 1.
    • Insert a metal spudger in between white plastic and rubber seal and gently drag spudger around see you lifting gently much like opening a can.
  4. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: adım 4, 1 resimden 1.
    • Align slits on the bottom of new suction seal then press into those slits.
    • The seal should not come above white plastic.
    • If the nozzle does not connect to vacuum barrel, readjust seal and try to attach nozzle until it snaps into place.
Sonuç
Roberto Perez
101 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
Where can I buy a new suction seal.
Alison Junk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 2,348
