Ana içeriğe geç
Black and Decker Dustbuster CHV1510 Battery Pack Replacement
Neye ihtiyacın var
  1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: adım 1, 2 resimden 1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: adım 1, 2 resimden 2.
    • Remove the six exterior 2 mm Phillips #0 screws securing the 2 halves of the white shell together.
  2. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 2, 2 resimden 1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 2, 2 resimden 2.
    • Remove nozzle by pressing two blue buttons on the side of the nozzle
  3. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 3, 2 resimden 1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 3, 2 resimden 2.
    • Remove the dustbin by pressing the blue button on the vacuum's handle and lift the bin from the vacuum.
  4. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 4, 3 resimden 1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 4, 3 resimden 2. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 4, 3 resimden 3.
    • Gently separate the two halves by pulling them apart, revealing the 14 cell battery pack behind the motor.
  5. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 5, 2 resimden 1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 5, 2 resimden 2.
    • Removal of the battery pack is a tool-less process, lift the battery pack out of the vacuum gently, notice there are two wires connected to the battery.
  6. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 6, 2 resimden 1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: adım 6, 2 resimden 2.
    • Disconnect the red wire from the battery pack (pull do not twist!) and do the same with the black wire
  7. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: adım 7, 3 resimden 1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: adım 7, 3 resimden 2. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: adım 7, 3 resimden 3.
    • Holding the battery pack firmly, disconnect the red and black wires from the battery pack by pulling them gently.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Miguel Vilao
376 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S7-G6, Baechle Fall 2017 IUPUI, Team S7-G6, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S7G6
3 Üyeler
Bir Yorum
The battery pack in no longer available and the 14 cells would cost more than a brand new dustbuster (Feb 25, 2021). I managed to get almost 10-years out of my CHV1510.
glenn.watkins - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 4,106
