Ana içeriğe geç
Black and Decker Dustbuster HNVC115J22 Motor Replacement
Neye ihtiyacın var
  1. Black and Decker Dustbuster HNVC115J22 Motor Replacement, Motor: adım 1, 2 resimden 1. Black and Decker Dustbuster HNVC115J22 Motor Replacement, Motor: adım 1, 2 resimden 2.
    • Press the button above the dustbin and separate the dustbin from the handle.
  2. Black and Decker Dustbuster HNVC115J22 Motor Replacement: adım 2, 1 resimden 1.
    • Remove five screws from the handle using a Phillips #1 screwdriver.
  3. Black and Decker Dustbuster HNVC115J22 Motor Replacement: adım 3, 2 resimden 1. Black and Decker Dustbuster HNVC115J22 Motor Replacement: adım 3, 2 resimden 2.
    • Pry open the two halves of the case.
  4. Black and Decker Dustbuster HNVC115J22 Motor Replacement: adım 4, 2 resimden 1. Black and Decker Dustbuster HNVC115J22 Motor Replacement: adım 4, 2 resimden 2.
    • Lift the motor and circuitry out of the plastic casing using your hands.
    • Pry out the PCB using a nylon spudger.
  5. Black and Decker Dustbuster HNVC115J22 Motor Replacement: adım 5, 1 resimden 1.
    • Separate the motor leads from the PCB with a pair of needle nose pliers.
    • Be careful not to break the new motor leads as they can be fragile.
  6. Black and Decker Dustbuster HNVC115J22 Motor Replacement: adım 6, 1 resimden 1.
    • Using a pair of pliers, insert the metal prongs of the new motor into the PCB.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 743
