Ana içeriğe geç
Black and Decker G48TD Disassembly
Neye ihtiyacın var
  1. Black and Decker G48TD Disassembly, Black and Decker G48TD Disassembly: adım 1, 2 resimden 1. Black and Decker G48TD Disassembly, Black and Decker G48TD Disassembly: adım 1, 2 resimden 2.
    • Open the grill.
  2. Black and Decker G48TD Disassembly: adım 2, 3 resimden 1. Black and Decker G48TD Disassembly: adım 2, 3 resimden 2. Black and Decker G48TD Disassembly: adım 2, 3 resimden 3.
    • Remove the top and bottom griddle plates.
  3. Black and Decker G48TD Disassembly: adım 3, 3 resimden 1. Black and Decker G48TD Disassembly: adım 3, 3 resimden 2. Black and Decker G48TD Disassembly: adım 3, 3 resimden 3.
    • Use a pair of Large Needle Nosed Pliers to twist the metal tabs holding the plate housing the bottom heating element connections and remove the plate.
  4. Black and Decker G48TD Disassembly: adım 4, 3 resimden 1. Black and Decker G48TD Disassembly: adım 4, 3 resimden 2. Black and Decker G48TD Disassembly: adım 4, 3 resimden 3.
    • Use a pair of Large Needle Nosed Pliers to twist the metal tabs holding the plate housing the top heating element connections and remove the plates.
  5. Black and Decker G48TD Disassembly: adım 5, 3 resimden 1. Black and Decker G48TD Disassembly: adım 5, 3 resimden 2. Black and Decker G48TD Disassembly: adım 5, 3 resimden 3.
    • Use pliers to twist the metal tabs holding down the thermostat housing.
  6. Black and Decker G48TD Disassembly: adım 6, 2 resimden 1. Black and Decker G48TD Disassembly: adım 6, 2 resimden 2.
    • Use a 4 mm Flathead screwdriver to remove the 11.4 mm screw in the back of the thermostat housing.
  7. Black and Decker G48TD Disassembly: adım 7, 2 resimden 1. Black and Decker G48TD Disassembly: adım 7, 2 resimden 2.
    • Lift up the thermostat housing and detach it from the temperature control arm, then remove the washers at the end of the temperature control arm.
  8. Black and Decker G48TD Disassembly: adım 8, 2 resimden 1. Black and Decker G48TD Disassembly: adım 8, 2 resimden 2.
    • Remove the thermostat housing.
  9. Black and Decker G48TD Disassembly: adım 9, 2 resimden 1. Black and Decker G48TD Disassembly: adım 9, 2 resimden 2.
    • Remove the thermostat housing springs.
  10. Black and Decker G48TD Disassembly: adım 10, 2 resimden 1. Black and Decker G48TD Disassembly: adım 10, 2 resimden 2.
    • Bend up the brackets holding down the heating elements.
  11. Black and Decker G48TD Disassembly: adım 11, 2 resimden 1. Black and Decker G48TD Disassembly: adım 11, 2 resimden 2.
    • Remove the heating elements from their respective housings (the bottom one is not able to be removed completely as it is fused to a piece of metal).
  12. Black and Decker G48TD Disassembly: adım 12, 2 resimden 1. Black and Decker G48TD Disassembly: adım 12, 2 resimden 2.
    • Remove the housing from the wiring along the bottom of the grill.
  13. Black and Decker G48TD Disassembly: adım 13, 1 resimden 1.
    • The device is fully disassembled!
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 433
