Ana içeriğe geç
Black and Decker IR02V-T Power Cord Replacement
Neye ihtiyacın var
  1. Black and Decker IR02V-T Power Cord Replacement, Power Cord: adım 1, 3 resimden 1. Black and Decker IR02V-T Power Cord Replacement, Power Cord: adım 1, 3 resimden 2. Black and Decker IR02V-T Power Cord Replacement, Power Cord: adım 1, 3 resimden 3.
    • Remove the two silicone covers which encase the screws.
    • Remove both 1 mm screws using a T5 Torx screwdriver.
    • Pry open the plastic cover starting from the top of the iron.
  2. Black and Decker IR02V-T Power Cord Replacement: adım 2, 3 resimden 1. Black and Decker IR02V-T Power Cord Replacement: adım 2, 3 resimden 2. Black and Decker IR02V-T Power Cord Replacement: adım 2, 3 resimden 3.
    • Remove both caps from the end of the wire by using pliers.
    • Unfold the metal in the caps using the pliers to release the exposed wire.
    • Remove the two 1 mm screws holding down the wire using a Phillips #00 screwdriver.
    • Once the wires are exposed separate and fold to opposite sides.
  3. Black and Decker IR02V-T Power Cord Replacement: adım 3, 3 resimden 1. Black and Decker IR02V-T Power Cord Replacement: adım 3, 3 resimden 2. Black and Decker IR02V-T Power Cord Replacement: adım 3, 3 resimden 3.
    • Remove the old power cord from the iron completely.
    • Insert the new cord through the plastic cover and hole of the iron as demonstrated in the image.
  4. Black and Decker IR02V-T Power Cord Replacement: adım 4, 3 resimden 1. Black and Decker IR02V-T Power Cord Replacement: adım 4, 3 resimden 2. Black and Decker IR02V-T Power Cord Replacement: adım 4, 3 resimden 3.
    • Expose about half an inch of wire by removing the silicone that encases it.
    • Tie the new wire into a knot and connect the wires accordingly.
    • Place the caps over the exposed wire and use pliers to tighten the metal to secure the wire.
  5. Black and Decker IR02V-T Power Cord Replacement: adım 5, 3 resimden 1. Black and Decker IR02V-T Power Cord Replacement: adım 5, 3 resimden 2. Black and Decker IR02V-T Power Cord Replacement: adım 5, 3 resimden 3.
    • Once the caps are over the wires add the two 1 mm Phillips screws along with the small base plate which secures the wire.
    • When all wires are secure place the plastic cover and screw back in the 1mm Torx screws.
Bitiş Çizgisi
Kevin B
146 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 43
Her zaman: 1,248
