Ana içeriğe geç
Giriş
The motor compartment is located on the bottom of the juicer. In this compartment there are many wires. Make sure the machine is off and unplugged before accessing the compartment. Use caution when working with the wires as electric shock can happen.
Parçalar
Hiçbir parça belirtilmedi.
  1. To replace the motor compartment, first follow the Disassembly Guide here
  2. Use the 2.5 mm Flathead adapter to remove the 13.5 mm screws from the bottom of the juicer. The screw head diameter is 5.2 mm. Use the 2.5 mm Flathead adapter to remove the 13.5 mm screws from the bottom of the juicer. The screw head diameter is 5.2 mm.
    • Use the 2.5 mm Flathead adapter to remove the 13.5 mm screws from the bottom of the juicer. The screw head diameter is 5.2 mm.
  3. Carefully remove the bottom off the rest of the machine. Carefully remove the bottom off the rest of the machine.
    • Carefully remove the bottom off the rest of the machine.
  4. Lay the juicer horizontally and roll the top shaft cover until it comes off.
    • Lay the juicer horizontally and roll the top shaft cover until it comes off.
  5. Unscrew the 19.1 mm screws inside the juicer holding the motor compartment attached to the juicer. Use the 2.5 mm Flathead adapter as the screw driver. The diameter of the screw head is 7.1 mm.
    • Unscrew the 19.1 mm screws inside the juicer holding the motor compartment attached to the juicer. Use the 2.5 mm Flathead adapter as the screw driver. The diameter of the screw head is 7.1 mm.
  6. Remove the motor compartment from the juicer and it is ready to be replaced. Remove the motor compartment from the juicer and it is ready to be replaced. Remove the motor compartment from the juicer and it is ready to be replaced.
    • Remove the motor compartment from the juicer and it is ready to be replaced.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bhavika Shah
265 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team 5-5, Blackwell Fall 2015 USF Tampa, Team 5-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S5G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
Her zaman: 471
