Ana içeriğe geç
Giriş
The cutter is located inside the machine so some disassembly is required. The cutter is sharp, use caution when handling it.
  1. To access the cutter, follow steps 1-3 in the Disassembly Guide.
  2. Place a hand on each side of the cutter and firmly pull vertically up.
    • Place a hand on each side of the cutter and firmly pull vertically up.
    • The teeth in the cutter are sharp and will cut you. Do not put your hand on or near the teeth.
Sonuç
AvaAnne Hogue
456 İtibar
4 adet Kılavuz yazıldı
Takım
USF Tampa, Team 5-5, Blackwell Fall 2015 USF Tampa, Team 5-5, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S5G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 519
