Ana içeriğe geç
Black and Decker JS660 Angle Knob Replacement
Neye ihtiyacın var
  1. Black and Decker JS660 Angle Knob Replacement, Base: adım 1, 2 resimden 1. Black and Decker JS660 Angle Knob Replacement, Base: adım 1, 2 resimden 2.
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Angle Knob Replacement: adım 2, 1 resimden 1.
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Angle Knob Replacement: adım 3, 2 resimden 1. Black and Decker JS660 Angle Knob Replacement: adım 3, 2 resimden 2.
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Angle Knob Replacement, Angle Knob: adım 4, 3 resimden 1. Black and Decker JS660 Angle Knob Replacement, Angle Knob: adım 4, 3 resimden 2. Black and Decker JS660 Angle Knob Replacement, Angle Knob: adım 4, 3 resimden 3.
    • As soon you disassemble the device, you can see the angle knob is not attached to any screws.
    • Remove the angle knob from the device.
Sonuç
Andrew Khouri
468 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-2, Eyestone Spring 2016 USF Tampa, Team 6-2, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S6G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 260
