Ana içeriğe geç
Black and Decker JS660 Power Cord Replacement
Neye ihtiyacın var
  1. Black and Decker JS660 Power Cord Replacement, Housing Disassembly: adım 1, 2 resimden 1. Black and Decker JS660 Power Cord Replacement, Housing Disassembly: adım 1, 2 resimden 2.
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Power Cord Replacement: adım 2, 1 resimden 1.
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Power Cord Replacement, Power Cord: adım 3, 1 resimden 1.
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Power Cord Replacement: adım 4, 1 resimden 1.
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Power Cord Replacement: adım 5, 1 resimden 1.
    • Gently remove the black and white cord from the trigger assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
matt murray
682 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-9, Maness Winter 2017 Cal Poly, Team 22-9, Maness Winter 2017 üyesi
CPSU-MANESS-W17S22G9
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 805
