Giriş
This guide shows the owner how to replace the power cord on their jig saw if it is cut or damaged. It is a very common way to render the saw useless. luckily the fix is quite easy.
Neye ihtiyacın var
Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
Bir başkası bu kılavuzu tamamladı.
