Ana içeriğe geç
Black and Decker JS660 Shoe Plate Replacement
Neye ihtiyacın var
  1. Black and Decker JS660 Shoe Plate Replacement, Housing Disassembly: adım 1, 2 resimden 1. Black and Decker JS660 Shoe Plate Replacement, Housing Disassembly: adım 1, 2 resimden 2.
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Shoe Plate Replacement: adım 2, 1 resimden 1.
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Shoe Plate Replacement, Shoe Plate: adım 3, 1 resimden 1.
    • Remove the 6.3mm hex screw on the left with a H.30 hex screwdriver.
    • Remove the reverse threaded 6.9mm black hex screw on the right with a H.40 hex screwdriver.
  4. Black and Decker JS660 Shoe Plate Replacement: adım 4, 1 resimden 1.
    • Simply remove the shoe plate by pulling it down and out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
matt murray
682 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-9, Maness Winter 2017 Cal Poly, Team 22-9, Maness Winter 2017 üyesi
CPSU-MANESS-W17S22G9
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Thank you! Looked all over for this.
Rick Weaver - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 1,715
