Ana içeriğe geç
Black and Decker JS660 Trigger Replacement
Neye ihtiyacın var
    1. Black and Decker JS660 Trigger Replacement, Housing Disassembly: adım 1, 2 resimden 1. Black and Decker JS660 Trigger Replacement, Housing Disassembly: adım 1, 2 resimden 2.
      • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Black and Decker JS660 Trigger Replacement: adım 2, 1 resimden 1.
      • By separating the two housing halves, carefully remove the top plate.
      FixBot'a Sor
      Yorum Ekle
    1. Black and Decker JS660 Trigger Replacement, Power Cord: adım 3, 1 resimden 1.
      • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Black and Decker JS660 Trigger Replacement: adım 4, 1 resimden 1.
      • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
      FixBot'a Sor
      Yorum Ekle
    3. Black and Decker JS660 Trigger Replacement: adım 5, 1 resimden 1.
      • Gently remove the black and white cord from the trigger assembly.
      FixBot'a Sor
      Yorum Ekle
    1. Black and Decker JS660 Trigger Replacement, Trigger: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use tweezers to press down on these tabs on the trigger assembly.
      • While the tab is depressed, the cord can be pulled out of the housing by using a moderate amount of force.
      • Each cord needs to be done separately.
      FixBot'a Sor
      Yorum Ekle
    2. Black and Decker JS660 Trigger Replacement: adım 7, 1 resimden 1.
      • Remove pink wires from trigger assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
matt murray
682 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-9, Maness Winter 2017 Cal Poly, Team 22-9, Maness Winter 2017 üyesi
CPSU-MANESS-W17S22G9
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,804
