Ana içeriğe geç
Black and Decker LDX172C Battery Replacement
Neye ihtiyacın var
  1. Black and Decker LDX172C Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Battery Replacement: adım 2, 1 resimden 1.
    • Rotate the drill to it's left side - the chuck should be facing rightward. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Battery Replacement: adım 3, 1 resimden 1.
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the 18650-2 Lithium Ion battery in the base of the drill.
  4. Black and Decker LDX172C Battery Replacement: adım 4, 3 resimden 1. Black and Decker LDX172C Battery Replacement: adım 4, 3 resimden 2. Black and Decker LDX172C Battery Replacement: adım 4, 3 resimden 3.
    • The positive and negative wires are connected to the battery via solderless connectors. To remove the battery, simply remove the wires by pulling the connectors apart. There are 3 connectors total.
    • Exchange the old battery for the new one.
    • Repeat steps in reverse to reassemble.
    • These connectors could be tight, it might be necessary to use a small pair of pliers to remove the wires.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Casey
260 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Wilson Spring 2016 IUPUI, Team 3-3, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S3G3
4 Üyeler
7 adet Kılavuz yazıldı
5Kılavuz Yorumları
I’m finding 18650 batteries. Is 18650-2 just 2 of the 18650’s or is it a preconnected set of 2?
I was able to pull the prongs off of the connectors, but the connectors don’t come off of the batteries, am I supposed to remove them? Are these supposed to be used/soldered to the new batteries?
What is the mAh capacity on the existing batteries, each of them? and would any mAh above that work?
I see the instructions mention soldering, but no mention in the steps of when soldering would be necessary. I’m assuming in attaching the connectors to the batteries?
Thanks,
Nav - Yanıt
thanks . it helped a lot.
one comment ,i had to take out 10 fastners instead of 8 as mentioned .the extra two are those which connect red part to black part.
Atul Goyal - Yanıt
I have to travel overseas with the drill and need to remove the Lithium batteries each time before checking the drill into checked luggage. Is there an easy way to remove battery to carry on board?
Jane Brinton - Yanıt
Hi Jane,
Unfortunately, this drill is designed without an easy way to remove the batteries. As a last resort, you can try cutting out a hole in the plastic enclosure in order to access the batteries easier.
Arthur Shi -
....and where does one get the replacement battery?
Gunnar Strand - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 50
Son 30 gün: 174
Her zaman: 5,341
