Ana içeriğe geç
Black and Decker LDX172C Trigger Switch Replacement
Neye ihtiyacın var
  1. Black and Decker LDX172C Trigger Switch Replacement, Trigger Switch: adım 1, 1 resimden 1.
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Trigger Switch Replacement: adım 2, 1 resimden 1.
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Trigger Switch Replacement: adım 3, 1 resimden 1.
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
  4. Black and Decker LDX172C Trigger Switch Replacement: adım 4, 3 resimden 1. Black and Decker LDX172C Trigger Switch Replacement: adım 4, 3 resimden 2. Black and Decker LDX172C Trigger Switch Replacement: adım 4, 3 resimden 3.
    • Remove trigger from drill by pulling the mechanism directly up off the holding pins.
    • The leads from the switch are removed by using a heating the solder until they come free.
    • Re-solder the leads to the new switch.
    • Repeat directions in reverse to reassemble.
Sonuç
jakebontragersinger
119 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Wilson Spring 2016 IUPUI, Team 3-3, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S3G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 3,227
