Ana içeriğe geç
Black and Decker PS1800 Actuator Fwd/Rev Replacement
Neye ihtiyacın var
  1. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Open the Outer Drill Case: adım 1, 2 resimden 1. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Open the Outer Drill Case: adım 1, 2 resimden 2.
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800  Actuator Fwd/Rev Replacement: adım 2, 1 resimden 1.
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: adım 3, 3 resimden 1. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: adım 3, 3 resimden 2. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: adım 3, 3 resimden 3.
    • Start separating the outer shell into two parts.
    • You will find the Fwd/Rev actuator on the right side of the drill, underneath the motor.
  4. Black and Decker PS1800  Actuator Fwd/Rev Replacement: adım 4, 3 resimden 1. Black and Decker PS1800  Actuator Fwd/Rev Replacement: adım 4, 3 resimden 2. Black and Decker PS1800  Actuator Fwd/Rev Replacement: adım 4, 3 resimden 3.
    • Carefully remove the actuator from the drill.
    • Replace the new actuator by inserting it the same way you took it out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hamza Nawaz
247 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Baechle Fall 2016 IUPUI, Team 2-3, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G3
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 812
